EF fuel pump upgrade
Old Jan 14, 2002 | 03:54 AM
Cory man's Avatar
Default EF fuel pump upgrade
Anyone using a GSR fuel pump in their B series powered EF? If so was the upgrade worth it? What are the wiring changes that need to be done? Are there any other mods? TIA
Old Jan 14, 2002 | 04:47 PM
-TJ's Avatar
-TJ
Default Re: EF fuel pump upgrade (Cory man)
If your going to the trouble to replace a fuel pump, I'd go ahead and buy a Bosch unit. They supply VOLUME, not just pressure.
Wiring on any FP is simple - 2 wires attach to the top of the pump.
Old Jan 14, 2002 | 06:33 PM
Bnjmn's Avatar
Default Re: EF fuel pump upgrade (-TJ)
The high pressure in tank Walbro units supply more volume at pressure (except at the extreme top range (above 80 psi) ) than the Bosch units. And the in tank models are about $115.
Ben
Old Jan 14, 2002 | 07:44 PM
Redline130's Avatar
I have an ITR pump in my CRX. Wiring is plug & play. You just need to transfer the ITR/GSR pump to the EF's fuel pump bracket. Only thing is, the ITR/GSR fuel pump is shorter than the EF's. If you can get the fuel pump to sit lower on the bracket, then you won't have to worry about keeping your gas at 1/8th tank or higher. I learned the hard way. HTH.
cyber13
Old Jan 15, 2002 | 07:59 AM
Eggman's Avatar
Default Re: EF fuel pump upgrade (cyber13)
how do you make the itr/gsr pump sit lower in the tank???
what r the specs on EF pumps? itr/gsr pump? bosch? i need to do some research before i decide to pull down the tank.
Old Jan 15, 2002 | 08:26 AM
-TJ's Avatar
-TJ
Default Bosch
The Bosch pump # is 10208 if you want to search around for data. It does require minor modification to the EF pump bracket to fit.
Old Jan 15, 2002 | 12:45 PM
therealciviczc's Avatar
Default Re: Bosch (-TJ)
Walbro makes an EF pump now. I just got one. Fits decent (hard to get in the tank) works very damn well. The car isn't too rich and is no longer lean.
autoperformanceengineering.com is where I got mine from.
Old Jan 15, 2002 | 12:50 PM
Eggman's Avatar
Default Re: Bosch (therealciviczc)
hey, thats pretty cheap. anyone try the holley?
Old Jan 15, 2002 | 03:40 PM
Default Re: Bosch (Eggman)
I think holly is walbro. Actually, its the other way around. Walbro makes the Holly pumps and they're cheaper.
dkboyny11
Nov 29, 2005 11:14 AM
puffsef
Mar 15, 2005 10:04 PM
red_hatch111
Feb 18, 2005 05:29 PM
wizzards581
Mar 22, 2004 04:09 PM
StorminMatt
10
Nov 15, 2003 07:01 PM
