lsvtec over b18c1
Old Jan 21, 2002 | 01:51 PM
96tegsr's Avatar
Default lsvtec over b18c1
I currently have a gsr with burned piston rings. I also have a b18a block sitting in my garage? Should i do an lsvtec or just fix the piston rings on my gsr and sell the ls block? Is the lsvtec worth it ove the gsr? if so, how much power and torque does it have more than the gsr?? TIA
Old Jan 21, 2002 | 04:37 PM
Jackson's Avatar
Default Re: lsvtec over b18c1 (96tegsr)
ls/vtec will make more power. just do it right. i would build the b18c though. or you can give it to me. i will build it.
Old Jan 21, 2002 | 05:54 PM
Kataku2K3's Avatar
Default Re: lsvtec over b18c1 (Jackson)
Sell the LS block and buy a B20, then toss ur GSR head on with some pistons and rods and you'll be set. CRVTEC will make some awesome power, just do it right.
Old Jan 21, 2002 | 06:12 PM
98 Ek LsVtec's Avatar
Banned
hey i'll buy your block off of you!!!
Old Jan 21, 2002 | 07:53 PM
96tegsr's Avatar
Default Re: lsvtec over b18c1 (98 Ek LsVtec)
how much?
Old Jan 21, 2002 | 07:56 PM
96tegsr's Avatar
how much power does a stock lsvtec have with a gsr head? any dyno?
Old Jan 24, 2002 | 09:03 PM
lsvtecracer's Avatar
Well, each ls/vtec engine produce different amount of power and torque depending on what you put together...Mine with a b16a head and ls block with ctr pistons put down 168 whp and 119 lbs of torque untune! Still waiting on my vtec controller to tune it...That's a pretty average number...Your gs-r will average a little bit more poewer and torque! Good luck with watever you decide.
Old Jan 24, 2002 | 09:04 PM
pissedoffsol's Avatar
25 Year Member
Default Re: lsvtec over b18c1 (lsvtecracer)
hrm.. that torque figure seems rather low comapred to what i've seen..
thoughts?
Old Jan 24, 2002 | 09:25 PM
Default Re: lsvtec over b18c1 (delvtecsol)
The torque number is pretty low.....We are thinking the reason it's low is because the car is running so rich...Because on the dyno, as soon as we hit 6000 rpm and the car start running rich the torque curve immediately begin to dip...I was expecting at least 125 lbs of torque actually. you have any explanation?? the air/ fuel goes for 12.8 down to 11.1 right after 6000 rpm..
And one more thing..Most people with high torque number all run jdm 4-1 header and i'm running a matrix 4-2-1 header..you think it has anything to do with it????
[Modified by lsvtecracer, 6:26 AM 1/25/2002]
[Modified by lsvtecracer, 6:28 AM 1/25/2002]
ser13
Apr 15, 2008 07:46 AM
kidd_drastic
Oct 30, 2005 01:12 PM
BoOsTiN Dc2
Dec 11, 2004 10:06 PM
JDM_Spec
Nov 25, 2004 10:45 AM
96tegsr
Jan 24, 2002 06:41 AM
