GSR swaybar on EG hatch
I installed the GSR lower control arms but the swaybar didn't fit because my exhaust was in the way. I've got a Greddy PE exhaust. How did you guys make it work?
Re: GSR swaybar on EG hatch (Pressurized)
Ditch the GSR bar for an ITR swaybar and if it does not fit, you just have to go on without one or the other.
There is no way around it, you have to reroute the exhuast if possible, get an exhuast system that doesn't get in the way, or simply not use the bar.
Good luck.
Good luck.
This happened to my friend that has an old school trust Greddy on his EG. He had the GSR sway, but it wouldn't work with the exhaust. So he removed the swaybar.
I'm not sure if the R bar will work or not . . .
Pressurized: The ITR bar is thicker (it's 22mm) and I really think you should get the ITR bar and new exhuast that'll fit with the bar installed.
dynamicRacing719
07-26-2004 08:12 PM
litterbox
05-10-2004 08:14 PM
speshuled619
08-06-2002 07:05 AM
JD_B18CDX
11
08-02-2002 09:26 AM
