For all LSVTEC's??
Old Jan 10, 2002 | 07:24 AM
ysrhatch's Avatar
New User
Default For all LSVTEC's??
what are the first symptons you guys experience when the motor is not broken into?? is the motor really loud and annoying? OR does it sound smooth like a stock car would sound? what other symptoms besides, oil and collant leaks do you guys experience when starting up this motor.
well my motor has 200 miles on it and still working on breaking it in. BUT i have a knocking noice coming from my block or head. its not that annoying but curious to find out what cuases that. please if anyone has any opinion or experiences please help. thanks.
Old Jan 10, 2002 | 07:48 AM
WAFFLES's Avatar
Default Re: For all LSVTEC's?? (ls_vtecer)
did you change all the bearings? Knocking is not good!
Old Jan 10, 2002 | 08:06 AM
Solo2Vtec's Avatar
Well just becuase it's a LS/Vtec it shouldn't leak. Well my car makes a tapping noise in the head. But that is a bad lost motion control assembly and does not effect performance or reliability. But is damn annoying!!!! I would break it in for about 800 or so mile and then mash out!!!!!
Old Jan 10, 2002 | 09:01 AM
HaUTSaauce's Avatar
New User
i never had ne of those symptom on my motor (crvtec) no knocking ad it ran fairly smooth
Old Jan 10, 2002 | 09:49 AM
Jackson's Avatar
Default Re: For all LSVTEC's?? (HaUTSaauce)
same here, my motor was very quiet and stock sounding. knocking is not good. you want to explain when and where the knocking is coming from? is it all the time, or under heavy load? whats the deal?
Old Jan 10, 2002 | 09:53 AM
ysrhatch's Avatar
New User
Default Re: For all LSVTEC's?? (Jackson)
everytime when starting up the motor theres knocking in the block. everything was install correctly. bearings are all changed and crankshaft regrind for new main bearings also. but when driving theres no problem, just happens when the car is idleing. please any suggestions.
Old Jan 10, 2002 | 10:27 AM
Solo2Vtec's Avatar
Sounds like rod knock you'll know it will seize
Old Jan 10, 2002 | 10:36 AM
Jackson's Avatar
is it loud? did you plastigauge everything when assembling it? did you adjust the valves when you put the head on? did you mill the head? what pistons are you using?
Old Jan 10, 2002 | 12:21 PM
stizzit's Avatar
is it a knock or a tick, if its a tick it could be many things. These include valve lash, injectors, bad piston pin, etc.
Old Jan 10, 2002 | 02:15 PM
ysrhatch's Avatar
New User
Default Re: For all LSVTEC's?? (stizzit)
well im using the b16a pr3 pistons with new rings and new rods with the stock ls rods. its a knock. and im sure its not the valves. valves have a tingleing sound but its a knock. only happens when idleing. any thoughts.
deerman2701
14
Dec 8, 2022 04:46 AM
firstclassjdm
Mar 9, 2005 10:40 AM
mugen92acintls
Aug 24, 2004 06:54 PM
EG6[B16A1]
Oct 31, 2003 07:43 AM
rizen
Sep 30, 2003 04:10 AM
