problem wit my hybrid
today i was driving my car and it started to shake bad for no reason then after 5mins it stopped shaking...does any1 know why it does that ? I just had my motor put in like last week and it make weird noises sometimes.
Re: problem wit my hybrid (AznInvasion)
What were you doing when it was shaking where you just sitting at a stoplight or where you driving down the street? We need more info.
Keith
Keith
Re: problem wit my hybrid (kwil666)
i started my car up and it started to skake and idel realy high. So then i went down the street and it kept doing this but then a few minutes later is stoped.
Re: problem wit my hybrid (SPOCK)
hmm...any check engine light or does your oil light come on at all?
i would say retorque your mounts but if its only when the car is cold that dosent make sense.
[Modified by KAMiN, 4:12 AM 1/25/2002]
Re: problem wit my hybrid (KAMiN)
yea my check engine light stays up all the time becuz of i have no O2 sensor i think and yea when my car warms up it stops shaking.
if you have no O2 sensor then you car isnt going to run right. you should get that fixed asap. if i remember right running with no O2 with make your car run really rich which can cause problems later down the road.
Keith
Keith
but the car shouldnt shake
i dont have an o2 sensor right now and it just bogs a little
check your codes i have a feeling its more than just the o2 sensor
New User
if the timing is wrong with the cam gears or the timing belt you will have a rough start up. you are running really rich right now so you might want to advance your ignition timming a little to get rid of that little bog. but you really need to get it fixed.
