b20vtec build
b20vtec build
Can someone tell me if all these parts will bolt on to each other and fit a EG6?
00 type r head complete wiring
98 b20 block, longblock
99 b16a tranny
98 gsr shift linkage
98 gsr axles
all motor mounts
95 obd1 gsr ecu
thanks
99 b16a tranny
98 gsr axles
all motor mounts
95 obd1 gsr ecu
thanks
Re: b20vtec build (chusai)
You'll need the VTEC oil line to go to the head and you need to have the Type R head bolts or the ARP bolts for the B18C. A breather kit would be nice too. Maybe throw in a clutch and flywheel if you can, but all those parts will set you back that you listed so you may be maxed out, I understand that!
