B16A P30 ECU question
Old Jan 11, 2002 | 12:55 AM
Spoon_Civic's Avatar
Default B16A P30 ECU question
Hi,
I'm running this P30 ECU with a 'chip'. But i notice that the ECU has got no knock sensor board. Is this safe?
http://hcoc.2u.com.my
Old Jan 11, 2002 | 03:22 AM
rainforest's Avatar
Default Re: B16A P30 ECU question (Spoon_Civic)
its just as safe as any other car without a knock sensor. alll you need to do is check your ignition timing from time to tima and you will not have any problems.
Old Jan 11, 2002 | 04:13 AM
eg6ajk's Avatar
if it has no knock sensor board then its a P08 ECU, that has been rechipped to DOHC VTEC specs
Old Jan 11, 2002 | 08:42 AM
B18C5-EH2's Avatar
Former Moderator
Loved
Default Re: B16A P30 ECU question (eg6ajk)
P28 doesn't have a knock sensor either...
SPOON, Mugen, Toda, etc. ECUs are nothing more than re-chipped P28 ECUs - NO knock sensor.
If it's good enough for them, then it's good enough for me
Old Jan 11, 2002 | 09:24 AM
SECRET AP1's Avatar
Default Re: B16A P30 ECU question (B18C5-EH2)
do obd-i p72s have knock sensor boards?
Old Jan 11, 2002 | 10:40 AM
B18C5-EH2's Avatar
Former Moderator
Loved
Default Re: B16A P30 ECU question (JDM EG6)
Yes, the P72 reads for the knock sensor.
However, you only need the P72 if you've got a dual-butterfly manifold from a B18C1 or H22A. don't go out of your way to get a P72 unless you need an ECU that will activate the secondaries.
Old Jan 11, 2002 | 10:42 AM
DragII's Avatar
there are obdi p30's though...from the 95-under del sol vtec. they don't have a knock sensor pin.
or are those ecu's coded differant?
Old Jan 12, 2002 | 07:42 PM
Default Re: B16A P30 ECU question (DragII)
I think the knock sensor board in a P30 ECU can be easily removed. This chipped ECU im running is really good. But i've got to dyno to find out. So far according to my 'butt' dyno....it ROCKS !
Scotty B
Mar 26, 2021 03:15 PM
CiviCVuE
Mar 13, 2007 06:00 PM
b16civicrida
Mar 2, 2006 02:36 PM
MadtownSi
Nov 14, 2003 08:46 PM
Eg6_JDM
Apr 14, 2002 07:47 PM
