LS Swap pics and a few vaccuum/wiring questions
LS Swap- 99% done
Does anyone know where this battery cable goes to??
And in the process of going from obd1>obd2, these hoses have no place to go. Does anybody know what to do with them?
Uhh, is this a factory integra ls mount?
Re: LS Swap pics and a few vaccuum/wiring questions (SolReaver)
Looking good! i don't know about the hoses, and that is an integra mount.
[Modified by youngkow, 10:32 PM 12/1/2002]
Re: LS Swap pics and a few vaccuum/wiring questions (youngkow)
cool stuff. You gotta take some better pics of the whole IM area, and you can probably get better help with the hoses. Please do that, I would like to look at things..
I'm pretty sure they're used somewhere. And yah, that's a teggy mount.
Starter power, should be an end that can be slid over a short stud sticking out of the top of the distributor, a ten mm nut goes over the end to clamp it down.
Where are the other ends connected?
The wire coming off the battery is for the ABS brake system. Just remove that wire. The other hose look to go from the charcol canister to the top of the intake manifold. The other hose looks to be the fuel return on the FPR??? Can't really tell from pics.
Re: LS Swap pics and a few vaccuum/wiring questions (97hb)
The hose with the red stitching (lol) goes to the top of the throttle body. Looks like the LS tb doesn't have that.. so don't worry about it.
The other, I'm clueless. Maybe it has something to do with the cruise control. You'll need to trace it to something and tell us what it is..
You need to run the larger of the 2 hoses from the canister to the input on the top of the intake manifold or your idle will be messed up when the motor is cold. I ended up just plugging the smaller one off...
Which ECU are you gonna be using? OBDI?
[Modified by JV, 4:09 PM 12/1/2002]
Re: LS Swap pics and a few vaccuum/wiring questions (JV)
You need to run the larger of the 2 hoses from the canister to the IAC on the top of the intake manifold or your idle will be messed up when the motor is cold. I ended up just plugging the smaller one off...
It's there on my ITR, but I don't see it on his.
Re: LS Swap pics and a few vaccuum/wiring questions (Nameless)
I don't think there is anything on the LS to fit that larger hose onto. I don't see it there, and I don't think he would be asking if he saw one there. No offense..
My bad, no need to get crabby. Mine is in a different place...
I wasn't trying to insult your intelligence.
[Modified by Nameless, 9:39 PM 11/30/2002]
Thanks a lot guys, i cant wait to get this motor started and running good. Yes i will be running a obd1 ls ecu. Now i just have to wait for the turbo to come in
i had that same problem, that power cable is acually not used, and either are the extra vacume lines.
I'm not mad. Just saying that i'm speaking from experience here, that's all...
I ran the Big Hose with the red on it to the Sensor on top of the IM (EVAP i think). and I also capped off ther smaller one..kinda sucks doing that i would much rather have a place for them.
