ITR Intake manifold in a B16 CRX
How easy is this mod. Do I need to make any major modifications or does it bolt right up? If you know a website that has info on this please post it or if you know please give me any info you have.
New User
Re: ITR Intake manifold in a B16 CRX (B16CRXhybrid)
i just did the manifold swap last week, it went fairly smooth. The only problem i had was hooking all the coolant lines up correctly. I also used RC 270's, a STR fuel rail, fuel pressure gauge, aeromotive fuel filter, vortech t-rex fuel pump, and a jg throttle body. I haven't had a chance to give the car a good run yet. I'm getting a CEL code 1 I think it's from the fuel and coolant spilling on the o2 sensor.
Like the others have said, it's a very easy job. Just make sure that you use a GSR/ITR fuel rail or an aftermarket one. The B16 fuel rail won't work due to the location of the air temp sensor.
New User
Re: ITR Intake manifold in a B16 CRX (cyber13)
http://lyonel.8m.com - look though tech and how-to's.
Re: ITR Intake manifold in a B16 CRX (w00t!)
Yea my friend is just tossing on a 99-2000 Si intake manifold on his B18C with 1st Gen B16 head... His one right now has a fucked up FITV that i can't even close down..... so it idles at 2000-2500... oh well.... The ITR looks way better but he got his new intake manifold and throttle body for $75. We're just gonna drop a GSR head on in a few months so it's just a quick fix... Good luck with the ITR intake manifold
homey dont play dat
09-25-2006 05:06 AM
racingant
10-09-2005 08:15 PM
