After engine install, do you pour oil in the spark plug hole before you start it?
New User
Re: After engine install, do you pour oil in the spark plug hole before you start it? (youngkow)
Done about 10 builds or swaps....never done that before. I just put fluids in...let the fuel pump prime up and turn it over.
Re: After engine install, do you pour oil in the spark plug hole before you start it? (SiR831)
I confused.....why would you put oil in the spark plug hole?
Re: After engine install, do you pour oil in the spark plug hole before you start it? (hot_EG)
Upper cylinder lubrication.
Use storage foam (people use it to store engines like lawnmowers) or WD-40. Or, just don't use anything at all.
Sometimes I do, sometimes I don't.
Re: After engine install, do you pour oil in the spark plug hole before you start it? (Revolveu2)
So I guess it really doesn't make any difference. Thanks!
Re: After engine install, do you pour oil in the spark plug hole before you start it? (Nikolai)
Don't most people use assembly lube on the engine anyhow?
Nick
Nick
When you start a motor after is has been sitting a while, I always unplug the coil and crank the motor over until the idiot oil light in the dash goes out. This way I can confirm that the oil pump is infact circulating the oil. You can dump a little oil in the cylinder. About a teaspoon or so will help to raise compression with dry rings.
trosstrom
06-15-2017 11:17 AM
red civic standard
06-07-2004 03:53 PM
