92-96 H22 in a 93 Cx???
i'm looking into gettin this swap from http://www.hmotorsonline.com
i know what i gotta get to make it work....(mounts:Hcp,Hasport,Place racing...shift linkage,axles)
but since the 92-96 motor is obd1 already will it just plug into my factory harness or do i need to wire the lude harness to a civic harness???
also...i will need a resistor box for the injectors right???
i tryed this swap before with a 01' h22 and i couldn't get it running so i sold the swap...i heard obd1 is easier so everyone...tell me what you know....
-Poison(Brandon) i know you can help me -
Re: 92-96 H22 in a 93 Cx??? (hybridRhatch)
w00t....bout time you get the ***** to do this swap again
you can use the CX harness and take wires from the prelude harness to add to the CX harness.
for wiring:
- you'll have to do 4-wire o2 sensor since the CX has a 1 wire
- you'll have to add VTEC wiring which is easy since you've done many swaps before i'll send u the diagrams again if u need it
- you'll need to switch the CX injector wires to the prelude type and wire up the resistor pack which will come with the jdm h22 (also in the diagrams)
- and finally u'll need to exend the alternator wires, other than that, the swap is pretty much the same as B series swaps.
edit
oh, ya and the distributor, MAP, TPS, IACV, blah blah will plug right in to the prelude's connectors.
[Modified by poison, 5:53 PM 11/18/2002]
for wiring:
edit
Mischief_EG
15
06-15-2004 07:56 PM
RuffRhyno
06-28-2003 04:51 AM
b18c5eg
12-23-2002 02:22 PM
