will it pass visual test?
Old Nov 28, 2002 | 06:42 PM
00fbp's Avatar
Default will it pass visual test?
I recently bought a 93 civic cx and i was plannin on swapping a GSR motor in there but my friend said that when i go to a smog test it wont pass the visual. is that right? even if the GSR motor is completely stock? thanks
Old Nov 28, 2002 | 09:29 PM
Newman's Avatar
New User
Default Re: will it pass visual test? (00fbp)
Here's the scoop. Techincally a smog station will not smog your car if there's a swap in it, and they'll tell you to go to a smog referee to get them to pass the visual and tailpipe. Now, if your motor runs good (passes tailpipe w/out any problems), throws no codes, and your swap is clean (no wires all over the place, all vacuum hoses plugged up, smog **** all hooked up), then there is no problem with a referee passing you. Otherwise, if the smog station is naive, then they'll disregard the fact that it's a B18C motor and smog your car anyways... as long as it passes tailpipe. All depends on where you live too.
Been there & done it all different ways for years now so I know how most things operate.
dunkraze
Nov 17, 2004 07:42 PM
bigbacon2
10
Sep 1, 2004 03:25 PM
00fbp
Nov 29, 2002 05:53 AM
wizzards581
Jul 13, 2002 07:30 PM
