LS Swap Problems>>>HELP!!
Old Nov 25, 2002 | 10:35 AM
ls-t del sol's Avatar
Default LS Swap Problems>>>HELP!!
Im in the middle of my ls swap into my del sol, here are the problems im having:
1. Driver side axle nut refuses to come off, broke 2 breaker bars trying
2. In separating the ball joint from the lower arm, i broke the grease seal for the balljoint. Where can i find these?
Other than that, the swap has been easy so far. Thanks in advance
Old Nov 25, 2002 | 10:42 AM
youngkow's Avatar
Default Re: LS Swap Problems>>>HELP!! (SolReaver)
The seals, you can get from the dealer. or http://www.hondaautomotiveparts.com. Also, you will have to get a bigger, stronger breaker bar. I'm not trying to be a smart ***, but trust me, you can get it off. Also try heating the nut with a propane torch. I used a 1/2" ratchet with a 4 ft steel pole as a breaker, and i got it off. GOod luck!
Old Nov 25, 2002 | 09:01 PM
DX187VTEC's Avatar
Default Re: LS Swap Problems>>>HELP!! (youngkow)
Mine was easy...used a Impact gun...good thing 2 have...
Chris
Old Nov 25, 2002 | 10:28 PM
Slopoke's Avatar
Default Re: LS Swap Problems>>>HELP!! (DX187VTEC)
The first thing I do when I swap a motor is loosen the axle nuts, while the car is still on the ground. I also just use a 1/2 in ratchet and a pipe for better leverage.
If the car is already up in the air, just have someone step on the breaks while you loosen them.
Old Nov 25, 2002 | 10:39 PM
Tuan's Avatar
Default Re: LS Swap Problems>>>HELP!! (Slopoke)
Seriously, one time i had dremeled that bolt off. Took a couple of hours!!!
Old Nov 25, 2002 | 10:58 PM
ransack's Avatar
Chris
I hope to get to use urs from my swap...heh
95jeremie
12
Feb 18, 2008 02:17 PM
stackz
Sep 28, 2006 02:34 PM
DaMmniTz
18
Feb 9, 2005 02:58 AM
DRKSol
35
Mar 21, 2004 05:11 PM
spooncivicR
Mar 28, 2002 04:09 PM
