B18A1 into a 92 civic DX Hb
What all is needed to do this swap? I know I will need a hyrdo to cable kit. ANbody sell this besides hasport? Can I use integra mounts from a newer model? Thanks
Re: B18A1 into a 92 civic DX Hb (flat-blk-HB)
From all of the install i've seen, the 92-95 can use the stock inegra mounts from 95 and up. Also i haven't seen anyone else make the bracket for hydro to cable except hasports. Basically you'll need engine, tranny, axles, ecu, and the hydro to cable bracket.
Also, you will need:
obd1 injectors
obd1 distributor
obd1 ecu
Remember 90-91 b18a's are only 130hp.
With the money spent on getting this motor to work in your 5th gen, you could easily make a sohc vtec faster.
obd1 injectors
obd1 distributor
obd1 ecu
Re: B18A1 into a 92 civic DX Hb (Slopoke)
See that is what I am rocking now. 99 D16Y8 and I have a 89 d16A1 compelete motor..( HC pistons)..I could throw in that thing but who knows. Yeah I dont know what I am wanting to do.
junior_tm
10
05-14-2007 03:50 PM
4gencivicef9
01-22-2007 05:55 PM
