Prelude wiring (searched)
Hey guys a buddy of mine is putting a JDM H22 in his prelude (I dont know what gen the body style before this one ... Know my civic not my ludes) I need a wiring diagram for it ... it was the sohc non vtec version so any help would be great .. thanks guys !
Re: Prelude wiring (JDM_SIR_II)
Everything should be smooth. Only thing you are going to need to add is VTEC wiring.
Here's how to do it:
add wire to VTEC oil pressure sensor for ground (tap into Grn/Wht wire), ECU Signal leading to D6 pin-out on ECU and VTEC solenoid valve to ECU leading to A4 pin-out on ECU
good luck
good luck
