sensor broken
Old Nov 20, 2002 | 08:16 PM
FleXingMyEK's Avatar
Default sensor broken
okay got a h22a sitting in my shop with a broken throttle body sensor, you know the one that sits right behind da throttle body, I replaced it with my d16 throttle body sensor, will this work or will i have problems? cause it matches right up to the plug...
Old Nov 20, 2002 | 10:30 PM
Lysawy's Avatar
Default Re: sensor broken (FleXingMyEK)
TPS thats what you reffering to or the other one idle speed control?
Old Nov 21, 2002 | 04:26 AM
92b16vx's Avatar
Default Re: sensor broken (Cx Sir II)
Not absolute but if it fits it probably works I've transfered all sorts of small parts between motors and if they fit they worked but I've never messed with a h22 so try it if it does then good if it doesn't it's not going to be a pain to replace with the correct unit.
Old Nov 21, 2002 | 12:13 PM
92sleepR's Avatar
New User
if it mounts properly and it reads between 0.5v closed and 4.5-5v wide open then yes. I think all honda throttle sensors are universal.
Mike
Old Nov 21, 2002 | 07:38 PM
95c1v1cs1's Avatar
Default Re: sensor broken (92sleepR)
Are the Vtec sensors universal? And the thermostat sensor as well?
Old Nov 22, 2002 | 05:55 AM
92sleepR's Avatar
New User
Default Re: sensor broken (95c1v1cs1)
I know that the VTEC solenoid is universal. I'm not certain about the temp sensor but I imagine it is as well. Honda is very conservative that way. Why design several different parts for the same function. It makes more sense to design the block / head / TB / whatever, around universal sensor designs.
Mike
wingnut1985
Honda Motorcycles
Apr 21, 2018 12:31 PM
GsRwHiTe
Mar 22, 2004 03:08 PM
Inaniac
Aug 21, 2002 07:09 PM
