2000 B16a2 into a 92 hatch wiring problems
anyone good with wiring up swaps? i have a 92 hatch that i'm puttin a si motor in and have been gettin mixed feedback on the wiring, i need someone who knows whats goin on to help me, thanks jerome
Re: 2000 B16a2 into a 92 hatch wiring problems (SfbGsr)
If you got a 92 hatch it's interior wiring harness is set for VTEC so there is nothing you will have to do there.. You'll have to drop a wire into the harness for KS and maybe rewire the oxygen sensor... I've been postin a little in this topic and it should help you out... Good Luck https://honda-tech.com/zerothread?id=343648
Get a 00 GSR harness and you'll be good to go. It will plug into your shock tower harness and since you have a 92, the VTEC wires are already in the cabin side harness. You'll still need to wire up the knock sensor and possibly the O2 but that should be about it. You can keep all the OBDII electronics on the motor and run an OBDI ECU - chipped P28 or P30.
4g4me
04-22-2002 09:23 AM
