OBDI engine with OBDI harness to go in an OBDII Civic.... HOW???
Guest
Posts: n/a
one of my friends just bought an EK hatch, and want to put his JDM B16 from his EG (EH) Si hatch, but he has no OBDII engine wiring harness...
is there any way he can use the wiring harness out of the EG and put it in the EK, of, if not, what does he have to do to the OBDI engine wiring harness to make if fit in the OBDII car?
Re: OBDI engine with OBDI harness to go in an OBDII Civic.... HOW??? (Boosted97Lude)
That won't work every easy.... It would be a lot of work to use that harness.... The best thing would be to find a 96-98 DX or EX engine loom..... The EX is a lot easier even tho i've never got to use one... For my friend's GSR swap I rewired his DX so I had to swap around the IAC wiring and run all new wires out for VTS, VTM, KS, etc... With the EX you'll only have to run a wire for the KS. You will also need an OBD2 oil pump or just the outer housing to mount the Crankshaft Speed Fluctuation Sensor... It's pretty straight forward from there... Use 99-2000 Si rear motor mount bracket and the driverside upper mount that bolts to the block itself... If you still have the DX/CX motor mounts in the EK for the upper tranny mount and the driverside upper apron you will be fine... Keep us posted...
BigRonDawg
04-24-2006 06:04 AM
boostedcivicsir
16
05-09-2003 09:58 PM
