ECU question
Old Nov 19, 2002 | 01:53 PM
Stifler's Avatar
Default ECU question
I'm having B18C1 swapped into my 96 DX HB. Which ECU should I get? Stock ECU from the 1996 GS-R the motor came from?
or
Hondata?
newbie to swaps.
Old Nov 19, 2002 | 02:07 PM
Deomonte21's Avatar
Default Re: ECU question (ds9)
I did the GSR swap into my civic EX and used the stock ECU with a civic(Skunk 2 P28 chip)
Old Nov 19, 2002 | 04:11 PM
eg6ajk's Avatar
if the motor is OBDII (96-8) specs, then simply use then GSR ecu. if the motor is OBDI, then harness converter + OBDI ecu (gsr or chipped P08/P28 (remeber these do not operate IAB)
Old Nov 19, 2002 | 06:00 PM
poison's Avatar
I would do either/or. Hondata P28 or OBDII P72
elmejor
Aug 24, 2008 05:39 AM
soeurm
Apr 27, 2006 04:46 AM
EKtypeRhaTcH
10
Jan 10, 2005 11:01 PM
mrDFWmechanic
11
Oct 28, 2003 01:05 PM
