need help with a 90 DX
Old Nov 23, 2002 | 07:28 PM
MrSmith's Avatar
Default need help with a 90 DX
Car is a stock 4 door and its more of a beater than a project. Original motor thats starting to go. What would be the best "cheap" swap? The idea is reliablity not speed and of course the less money spent the better D16? ZC? What would be necessary with each swap? For example with the ZC is motor/tranny enough and can you use stock axles ecu etc? I tried searching but no luck. Thanks in advance.
Old Nov 26, 2002 | 10:34 AM
LoudAccord's Avatar
Default Re: need help with a 90 DX (MrSmith)
I would say just get a D16... I know of one that will be for sale
Old Nov 26, 2002 | 03:07 PM
poison's Avatar
Default Re: need help with a 90 DX (LoudAccord)
ZC would be the cheapest and easiest swap, although a D16 wouldn't be much more and you'd have to go OBD1, where as ZC plugs right in and all you need is the long block because your stock tranny and axles will work.
I have a D16 long block for sale, if you are interested let me know.
Old Nov 26, 2002 | 04:33 PM
LB CRX's Avatar
Default Re: need help with a 90 DX (poison)
are you guys forgetting that the 90 dx is dual injected? you would have to make a conversion for the mutijection and from my understanding have to get a resistor box as well.
hondacivic90zc
Apr 8, 2007 07:54 AM
monkeys_ninja
Apr 27, 2004 08:11 PM
x1racer
Dec 12, 2003 10:53 AM
c for sea
Oct 11, 2003 05:44 PM
Kasper.
10
Jun 20, 2002 12:40 PM
