Code 9 jdm pr3
Old Dec 7, 2002 | 05:44 PM
XzzYzzX's Avatar
Default Code 9 jdm pr3
I just put a 95 gsr in my 91 crx si and its throwing a code 9 i think, wats the problem i don't think the vacum hoses are hook up right i also think they have nothing to do with each other if someone could help i need help with the FPR one part goes to the fuel and the other end where does that go and on the right side of the IM in the back there is a hoes but when i put my finger over it i doesn't run right or if i hook it up to something it does the same thing Thanks
Old Dec 8, 2002 | 08:23 AM
XzzYzzX's Avatar
Default Re: Code 9 jdm pr3 (XzzYzzX)
Come on guys someone please help me......
Old Dec 8, 2002 | 09:50 AM
eg6ajk's Avatar
code 9 = check your distrbutor
Code Meaning
1 O2A - Oxygen sensor #1
2 O2B - Oxygen sensor #2
3 MAP - manifold absolute pressure sensor
4 CKP - crank position sensor
5 MAP - manifold absolute pressure sensor
6 ECT - water temperature sensor
7 TPS - throttle position sensor
8 TDC - top dead centre sensor
9 CYP - cylinder sensor
10 IAT - intake air temperature sensor
12 EGR - exhaust gas recirculation lift valve
13 BARO - atmospheric pressure sensor
14 IAC (EACV) - idle air control valve
15 Ignition output signal
16 Fuel injectors
17 VSS - speed sensor
19 Automatic transmission lockup control valve
20 Electrical load detector
21 VTEC spool solenoid valve
22 VTEC pressure valve
23 Knock sensor
30 Automatic transmission A signal
31 Automatic transmission B signal
41 Primary oxygen sensor heater
43 Fuel supply system
45 Fuel system too rich or lean
48 LAF - lean air fuel sensor
54 CKF - crank fluctuation sensor
58 TDC sensor #2
61 Primary oxygen sensor
63 Secondary oxygen sensor
65 Secondary oxygen sensor heater
Old Dec 8, 2002 | 09:51 AM
eg6ajk's Avatar
what distributor, injectors are you using?
Old Dec 8, 2002 | 11:52 AM
XzzYzzX's Avatar
Default Re: Code 9 jdm pr3 (eg6ajk)
i am using a JDM b16 distributor, and the stock crx si injectors.
Old Dec 10, 2002 | 02:18 PM
XzzYzzX's Avatar
Anyone know the problem?
Old Dec 10, 2002 | 03:18 PM
Kataku2K3's Avatar
If you are gettin a CEL for the cylinder position sensor then there is most likely something wrong with the sensor in the distributor or something isn't wired correctly... Do you have another distributor to test? If nothing checks out there my guess is something is wrong in the wiring... Check into it both at the distributor and at the ECU... I would also continuity test it to make sure the wire is still good.. Lemme know if you figure out anything else.. Good Luck
[Modified by JDMspecEG6, 4:19 PM 12/10/2002]
Laz's EP
22
Feb 22, 2010 12:09 AM
97civic123
Jul 13, 2007 04:14 PM
CustomX113
11
Sep 1, 2006 01:27 PM
xxthabest1xx
Mar 15, 2003 06:06 PM
cottagecreep
Jan 28, 2003 03:18 PM
