84-87 CRX B16 Header/Exhaust ?s
Looking for anyones knowledge on mendrel bant exhaust other than your typical local shop (crush bend) for this car. Want >2.25in. The question is will any other honda models exhaust fit or come close with some cut & weld. From searching this forum I found a 4-2-1 header will due from the Del Sol Vtec or 99+ Si. True? Thanks,
-Marc
-Marc
Re: 84-87 CRX B16 Header/Exhaust ?s (85SiR)
Pretty much any b16a header will work, but the exhaust basically has to be custom. Many muffler shops keep mandrel bends around that they can use to weld up an exhaust. Hell, even the minekie that I used to live near made mandrell bent exhausts.
[Modified by ATXhybrid, 12:26 AM 12/8/2002]
Re: 84-87 CRX B16 Header/Exhaust ?s (ATXhybrid)
Mendrel bends do not come cheep around Louisville, Ky area and when one of the two shops here who weld together custom exhaust systems you would be better off ordering a stainless system when you compera prices. So no one knows of any other applications that fit? As for the header, I will have the jdm header that came with the b16 port matched. for now since a turbo will be installed for next Solo II season.
