ITR LSD fit in a 2000 Si trans?
Re: ITR LSD fit in a 2000 Si trans? (Ehron)
Yes it does "fit" but, it is not a direct bolt in. You need to change out the final drive gear. Buy a Quaife. Save youself the time and $$
Moderator
Re: ITR LSD fit in a 2000 Si trans? (JDMspecEG6)
itr lsd will fit 2000 si tranny if you also use type r ring gear (goes around lsd) and b16 carriage bearings....
I DID IT!!!
I DID IT!!!
Ehron
10
12-05-2002 05:11 PM
