JDM P13 ECU Automatic Tranny VS. 5-speed Tranny Differences
Old 12-02-2002, 12:15 PM
apexi's Avatar
Default JDM P13 ECU Automatic Tranny VS. 5-speed Tranny Differences
Anyone know if P13 from an Auto Tranny will work with 5-Speed. The dealer that I bought the H22A Swap from gave me the wrong ECU. If not can this be mod to work?
Thanks in advance.
Old 12-02-2002, 12:34 PM
eg6ajk's Avatar
Default Re: JDM P13 ECU Automatic Tranny VS. 5-speed Tranny Differences (civic7)
yes it will work but CEL code as well as lower rev limit will be there.
but it can be chipped to 5spd, with either Spoon program (excellent ) or KS ROM
Old 12-02-2002, 12:43 PM
apexi's Avatar
Awesome! Thanks for the help.
Old 12-02-2002, 05:35 PM
Kataku2K3's Avatar
Yea just as any other... you'll get an automatic transaxle lockup code... unless you chip it out.... Peace
Old 05-15-2003, 10:48 PM
COMplex.'s Avatar
Default Re: JDM P13 ECU Automatic Tranny VS. 5-speed Tranny Differences (Kataku2K3)
sorry to bring this back from the dead...
but are you saying if i just use a spoon chip for 5spd ecu, everything will work perfect? no auto related CEL's?
Old 05-15-2003, 11:59 PM
Kataku2K3's Avatar
Default Re: JDM P13 ECU Automatic Tranny VS. 5-speed Tranny Differences (j.fuggi)
You can use the same proggy, just change around your auto to manual selection... If you need more help then let me know... Peace
Old 05-16-2003, 12:14 AM
COMplex.'s Avatar
yea i don't know what you mean.
i have a spoon chip that needs to be soldered into the ECU. and i have the JDM p13 auto ecu. 4 plugs and 4 wheel steering.
i hope its plug & play. please lol
Old 05-16-2003, 12:16 AM
H22AMedina's Avatar
I've used 2 JDM auto ecu's in my car and no problems whatsover, I got a 180 hp and 154 ft/lbs torque with it. I have a JDM H22 in a 97 civic btw. Only code I got was for my egr, since it's disabled.
Old 05-16-2003, 11:15 AM
apexi's Avatar
Finally got the engine in with the P13 Auto. For the record, there is not one CEL about the tranny. I'm getting the normal CELL errors MAP, IAC, EGR, Just get the Knock when it is rev hard. FYI... Knock, O2, MAP, EGR, and IAC does not have to be plug-in for the H22A w/Auto P13 to start. I ran mine 23 miles to garage to get the muffler plumbing fixed? Some say that you must have all the sensors plug-in to get it to run. Not true in my case.
asocallocal
07-21-2005 07:20 PM
5lugSlug
07-06-2005 08:11 PM
EJCivJdM93
01-26-2005 03:48 PM
d15bcrex
01-15-2004 09:27 PM
absolut b18
08-03-2003 12:38 PM
Quick Reply: JDM P13 ECU Automatic Tranny VS. 5-speed Tranny Differences
