what shift linkage should i use
i am putting a b16a2 us into my 92 vx , would i need a 95 delsol si shift linkage?
or could i use my 2000 si shift linkage?
thanx
thanx
Re: what shift linkage should i use (GReddy SI)
your right use the del sol shift linkage it should be $130-150 hasport sells em im pretty sure, how is the swap goin I just got my money to buy one now I have to decide where to get it and if i want a first or second gen
Any b series linkage 00 si,teg type R delsol vtec,whatever.I got 99 teg R on a 93 b16a2 in a 92 vx.works beautifully.
thanx
thanx
Reuse the 00 Si shift linkage you claim to have, it will work 100% with your VX + B16A2 engine + trans.
Re: what shift linkage should i use (Katman)
Rather than blowing my money on new linkage, I'm going to modify my EK linkage to work with a B18..I've found a little info on this, but does anybody else have and good links or insight on the best way to go about this?
Re: what shift linkage should i use (Hatchblack)
it will never fell the same.. I modified my stock d16 shift linkage when I did my swap.. I have a ej6 civic htbk.. and then I put a ITR linkage on there difference was way better shifting feel..but if your tight on money go for it .. I had it on for almost a year when I changed it
I used ls linkage from a 96 teg in my old cx. Worked fine. I believe that all of the b series linkages work except for the Del sol's as mentioned above.
Re: what shift linkage should i use (bigblockEG)
Why do people think the delsol won't work?my buddy took a delsol VTi and swapped everything into a 92 civic hatch just fine.Including the shiftlinkage.
HT's Biggest Loser
Re: what shift linkage should i use (92b16vx)
New User
the upper is a del sol, the lower is an integra.. i'm not sure how your friend got it to work when it's shorter AND bent differently.. strange that he's the only person i've ever heard it working for..
[Modified by bojangs, 1:14 AM 12/17/2002]
New User
..hrm odd, ok. I stand corrected.
[Modified by bojangs, 1:16 AM 12/17/2002]
Re: what shift linkage should i use (bojangs)
I'm sure Katman was right but I just had one question about that linkage... is the top one SOHC ****??? the torque rod bushing that bolts to the tranny looks like a SOHC design but I dunno...
Maybe in the states it's different(is the shift linkage in the picture from a b or d),or maybe he did something when nobody was looking,but his entire swap came from a sol VTi and he used all the parts.
Re: what shift linkage should i use (eg6ajk)
just get 90-3 integra linkage, much checper works like charm as well
New User
Re: what shift linkage should i use (JDMspecEG6)
