what tranny for b20 not the usual question??????
need to know of any problems with these two trannys. tranny one out of a 98 ls integra it has abs on it i will be getting everything i need for swap including, shift linkage,shift lever,axeles,half shaft,flywheel,and clutch which i probly wont use.
Tranny two: 99 ls not sure if it has abs on it yet same thing as before all parts listed above
My main worry is if the abs axeles are going to be a problem. The car they will go into will be a 97 civic and moter is a b20b4(97-US spec). The great thing is that both trannys are in the cars still and with in a 2k miles of each other(both under 65k),and they are the same price. To all who have done this swap, or a ls swap of the same years, my question is will the abs axles be a problem. PLESE HELP ME I NEED TO MAKE A DESION BY TOMAROW MORNING.
Re: what tranny for b20 not the usual question?????? (ef ect)
I believe you can use ABS axles in a non-abs vechile.. but you can not use a non abs axles in a abs vechile since they lack a sensor or somerthing on them...But from what I remember you can use any abs or non abs axles for your vechile..since u do not have abs
Re: what tranny for b20 not the usual question?????? (IM ALL BOB)
yea thats the conclusion i came too the guy at the yard is a freind and dose about 3 swaps a week he was very helpful and is going to lookout for me in the strip shop and make sure that nothing is cut or messed up. Any way i went with the 99 tranny had a better waranty 100 day vs. 60. All i need now is mounts to put it in and ill be pulling the car on the car port for the swap
ABS axles will work fine in a non-abs car. You will notice around the outer joint a gear looking thing. Its called a .... I want to say spanner but I dont think that is right. The word has slipped my mind. Anyways:
non-abs car + non-abs axles =
non-abs car + abs axles =
I would consider a GSR tranny for better gearing, that's the best tranny for a B20. The axels will work fine. I have a 99 B18C1 in my 92 VX and the axels were ABS and my car in non-ABS.
Re: what tranny for b20 not the usual question?????? (VTECVillain)
Any way I looked around for a gsr tranny and found a few and ether they were over priced or fairly priced and on the other side of the country. I have seen the ratio difrences for the two trannies and th ls is not that much difrent than the gsr and i like the idea of a good interstate tranny. Another thing is i want to boost the moter in some way hopefully with a vortec super charger, I think that is the one that is a turbo that is shaft driven. That should make the tranny shine.
To sum it up
Getting tranny and moter w/ lower compresion 200$ extra
Getting to see the cars they come out of and what happen to them and not to mention dealing with friends that will watch out for me priceless
not to mention i got tired of wating for a gsr tranny and the moter has ben sitting for 8 months, and taking valve cover and oil pan on and off to spray with wd40 every couple weeks is getting to be a pain in the ***. And what better way to spend the holidays than putting a b moter on your civic.
[Modified by ef ect, 6:18 PM 12/4/2002]
96pgtmtx
07-16-2007 03:46 PM
arsenaldragster
04-24-2005 10:49 PM
