Can N E 1 Help Me Out with My Swap?
Hey sup guys,
I'm new to this but What I wanna know is If i swap a 98 GSR motor thats a OBD2 engine into a 93 si hatchback And run a OBD 1 ECU will that run the motor correctly in my car? Or do you guys prefer just converting everything over and running OBD2 since the motor is OBD2? I was told that running the OBD 1 ecu on a obd 2 motor wouldn't effect the performance and would run the same and would be alot easier to install the wiring harness Since its OBD1 N E info can help!!!!. I also have a OBD2 98 GSR ECU that I am willing To trade for a OBD 1 if anyone has one for a trade or sale,or can help me out feel free to email me @ Chunkiye@hotmail.com THANKS!
Re: Can N E 1 Help Me Out with My Swap? (Chunkiye)
well actually it will affect the performance. u will run better with the obd1. and yes it will be easier to install cuz there are less stuff to hook up with the obd1.
Re: Can N E 1 Help Me Out with My Swap? (hondaZvic)
OBD1 ECU's have less parameters on the motor.... That's the reason they seem to run better.... I hate the stock OBD1 P72... It seems like the motor lags especially if you have the simplest mod being a CTR intake cam. The VTEC is too low for that cam and I hate the IAB ****.... I would recommend a chipped P28... They are simple, feel way stronger than the stock GSR or even a chipped GSR for that matter, have no IAB control (you can have the IAB's pinned open or just remove the plate as i do), and it doesn't look for KS input...
HT's Biggest Loser
You can locate them several ways, PM Cheetah on this HT Board, he gets them, or try http://www.jdmhondaparts or http://www.inlinefour.com. but ive had one of cheetahs, so to him, good luck
Cap'N Chronic
24
03-08-2014 09:30 AM
mikej94civex
10
02-12-2010 03:54 PM
reyrey2006
02-13-2009 08:26 PM
