Got a couple more GSR into CRX questions!
Actually, I just have one.., What do most of you do about the fuel line/ banjo fitting which is right in the way of where you connect your piping to the throttle body of a GSR manifold. I have the correct I/C piping for that manifold but it hits the metal fitting and line!!! Thanks for your suggestions..
Re: Got a couple more GSR into CRX questions! (V8 BAIT)
Just encountered another problem, what heater hoses work with the GSR into a CRX... Are there pre-formed Honda hoses which will fit well so that I don't have to ghetto route some 3/4 inch universal heater hose?!
For your 1st question. Just turn the fuel line upside down and it should fit. Take it completely off and flip it upside down and put it back on.
For your second question. Don't use a universal one because it's just way too big and will get in the way of everything else, also it doesn't bend too well. I forgot where I gotten mine from but I went to the junk yard and looked for a smaller hose just like the stock one but which has more of a bend to it and modified it to fit.
Anymore questions, just ask.
JohnnieChimpo
12-06-2004 08:05 AM
