What are some common things people forget to bring for a swap??
Im getting my ls/vtec swap done on friday and was wondering what was some of the common parts or things poeple tend to forget to bring?
I know i need to bring oil, antifreeze, and oil filter
What else would i need?
Also what are some common parts people forget to get for there motor when there doing a swap?
TIA
-Brian
TIA
-Brian
Re: What are some common things people forget to bring for a swap?? (vtec69)
oil, oil filter, transmission fluid, plugs, wires, antifreeze etc, really just a little small stuff when your almost done you end up having to go to like pep boys or autozone to get some oil and stuff.
Re: What are some common things people forget to bring for a swap?? (b18cInside)
Also how many gallons of antifreeze do I need for my 98 civic with the ls/vtec?
-Brian
Get some Grease for your CV Joints. Since the motor and tranny are already out, its always a good idea to change this stuff anyway. I would get new Transaxel seals too. Get some wires and wire connectors. Im sure there are going to be some things your going to need to change once you get the motor out. It always happens to me
Re: What are some common things people forget to bring for a swap?? (Havocprez)
New radiator hoses. You'll find that its quite a pain the *** making your stock hoses fit. For you EG guys, just go get them for the del sol VTEC model.
Anti-seize for plugs and other major bolts ..... Hose clamp-off set, small set of prybars, pickle fork(s), Castlenuts with Cotter Pins in case you "mushroom" one out by mistake ...... Uhmmmmm......
Advanced Timing Gun, PB-Blaster, Latex Gloves (in case you hate re-washing hands ), Hose Clamps, Roll Pin Punch w/ alignment tool for lining up Bolts.
I'm sure ther's more I can't remember ..... but you get the idea, usually people forget the smallest tools, don't ask me why .....
Please don't hurt me!
Re: What are some common things people forget to bring for a swap?? (ErikDaGenErik)
believe it or not, i know people that forget to bring the ecu, only because its not attached to the motor.
also i forgot the clutch fork and throw out bearing (tranny and motor werent together)
get some break fluid dot 3
Re: What are some common things people forget to bring for a swap?? (couter)
im using a type-r head
-Brian
Thanks for all your help so far!
-Brian
HT's Biggest Loser
oil, oil filter, transmission fluid, plugs, wires, antifreeze etc, Cool i have that stuff already is ther anything else?
Re: What are some common things people forget to bring for a swap?? (SIXTYdashONE)
you all are forgetting the most important.
20 pack of beer
[Modified by poison, 5:24 PM 12/11/2002]
20 pack of beer
Re: What are some common things people forget to bring for a swap?? (poison)
And a roll of toilet paper because you might ish yourself when you first get to drive it!!
PINKS
08-09-2006 02:19 PM
EngineNoO9
Honda Motorcycles
21
07-31-2006 06:10 PM
hookedonvtec
15
10-13-2004 01:12 PM
