o2 sensor causing limp mode
Old Dec 1, 2002 | 10:56 PM
OptimusPrime2k's Avatar
Default o2 sensor causing limp mode
Ok guys...my friend jsut did a swap from my 97hx and put a 99 si engine in it...we are using a 97 gsr ecu...he started the car BEFORE putting the o2 sensors in....I was told this would put it in "limp mode".....Now i was alo told i can only get this reset by a dealer or someone with a labtop program because it has to do with emissions...is this true?.....apparetly its not jsut normally resetting the ecu...thanx
Old Dec 2, 2002 | 10:47 AM
b16ahybrid's Avatar
Default Re: o2 sensor causing limp mode (OptimusPrime2k)
Just disconnect the battery for a few min, the ecu will reset....
Old Dec 2, 2002 | 06:07 PM
HXMan's Avatar
I assumed you used the Hx harness....
You are going to need to do alot more work then just get the ECU programmed, or try to reset it.
You have to rewire the Primary O2 sensor completly.
Old Dec 2, 2002 | 06:24 PM
ekhatchhybrid's Avatar
Default Re: o2 sensor causing limp mode (HXMan)
can not haveing the 02 sensor hooked up really cause the car to go into a limp mode?? in another words loss of power??
Old Dec 3, 2002 | 05:42 AM
integra6650's Avatar
Default Re: o2 sensor causing limp mode (ekhatchhybrid)
yes i had a 99 gsr turbo and when i was hooking the o2 sensor back up after an exhaust change i mixed up some wires started the car and it went into the slow mode even after i reset it it still ran shitty i was running like mid-high 12 and after the slow mode i couldn't run under a 14 flat
Old Dec 3, 2002 | 12:49 PM
HXMan's Avatar
Default Re: o2 sensor causing limp mode (integra6650)
That wasn't your O2 sensor then.
My best times with just a b16a2 swap in my hx being run with a GSR ecu was when my car had a CEL for both o2 sensors. I was also getting 29mpg with no o2 sensors.
O2 sensor codes will NOT put you into limp mode.
Old Dec 3, 2002 | 04:46 PM
jas0n's Avatar
Please don't hurt me!
my o2 is just hanging down since i ordered a bunge for it cause theirs no spot in my headers or exhaust
could that be why my car is running slower than suppose to be
Old Dec 4, 2002 | 07:28 AM
SpooN Man's Avatar
Default Re: o2 sensor causing limp mode (couter)
Even if you disconect the o2 sensor(s), It will not send a car into limp mode.
GReddy_Civic
Oct 20, 2009 06:39 AM
turbo gli
Jun 6, 2009 12:29 PM
NightHawkBlack-R
Feb 16, 2009 10:28 AM
adrenajunky
Oct 13, 2004 06:18 PM
arjusmc
Oct 23, 2003 04:26 PM
