which alt. belt for swap???????
have an 88 crx with itr motor and need to know which alt. belt will fit? do i just get some string and take it to the auto store??? what about adjustments??
Re: which alt. belt for swap??????? (b18crx)
Re: which alt. belt for swap??????? (Revolveu2)
thanks...
its just that there's no room. ive banged out the area for the alt. and it seems id need a new belt. running the N-1 pully to save room. ill use the string to make sure
For those who don't know (as it seems there are a few):
The alternator is really close to the frame rail for a 88-91 Civic/CR-X B-series swap so it is recommended that you get a smaller belt to pull the alternator closer to the engine.
String or tape measure is good to use. Going an inch down from the current size is a good starting point. I used a 305K4.
[Modified by markpaco, 1:11 AM 12/2/2002]
ehrkeith
03-26-2012 12:29 PM
