What Throttle Cable To Use on b16a II??
Re: What Throttle Cable To Use on b16a II?? (badCRX)
Thanx for the info. I just did the swap this weekend and the car runs but the org. sohc thorttle cable is not compatible. Cant wait to test drive....thanx again...
Not any B series without modifying the bracket... but turboorangecx you are right about that... the Del Sol throttle cable would probably be your best bet... Good Luck
Re: What Throttle Cable To Use on b16a II?? (JDMspecEG6)
I used a 90-93 integra throttle cable and it worked fine for me. $30 from a salvage yard or $5 at a pull-a-part
2camsaam
09-12-2003 08:20 PM
