ITR IM on a GSR head
Anyone know the details??
A link to a how-to would just brighten my day up a wholllle lot.
I dont really need any info on aftermarket stuff since I know some of you would probably say.... Skunk2 or JG. Isnt allowed in the class Im running.
Thanks for the info & a link!!
Pete
Pete
Re: ITR IM on a GSR head (KAMiN)
Possible?? Im pretty sure someone's tried or has successfully done it.
If I have to drill... so be it. Im just more worried aobut the water coolant passage not lining up. Wish I had the stuff lying around so I can test... but I dont
Pete
Pete
Re: ITR IM on a GSR head (pest)
I did it on my first GSR motor. I bought a brand new Type-R manifold and had a good welding shop weld on a piece of aluminum stock on where the coolant passage is for the heater. Filed the hole so that coolant could flow from the head to the hose fitting. Then I had a machine shop resurface the manifold. Used the Type-R gasket for a template and drilled the holes I needed to get the manifold to bolt up to the head. I forget now which holes lined up, top or bottom. This was in '99 and I had not heard of the Skunk2 manifold at that time.
Re: ITR IM on a GSR head (XtraFastCRX)
Wouldnt you save yourself alot of headache, time, and money buy going with the skunk2 replacement mani that is ITR "style"? It will bolt right up as well.
Re: ITR IM on a GSR head (b19coupe)
OEM ITR looks way cleaner.... The SK2 looks cheap.... Just my opinion... but you will have to do the modifications that b19coupe said to to run the ITR intake manifold on the P72 head...
He can't use aftermarket stuff in the class he is running, so Skunk2 is out.
The only way I've seen/heard of people doing it is by chopping the plate that mates with the head off of each intake manifold and welding the GSR plate to the ITR manifold. Sorry, cant offer much help.
[Modified by Slurp56, 10:56 PM 12/3/2002]
Re: ITR IM on a GSR head (Slurp56)
my friend did it. i believe he redrilled the holes for the studs, cut off the water passage and jb weld another one on. something like that. u can ask him at http://www.prospeed-performance.com
krazy
krazy
Re: ITR IM on a GSR head (krazy)
Erick's is doing the exact opposite... PR3 head with GSR manifold "shell".... Doesn't exactly have the dual stage runners anymore.... hehe... Latez
GSRCRXsi
36
03-09-2006 08:20 AM
GSRCRXsi
30
03-08-2006 06:14 PM
GSRCRXsi
Welding / Fabrication
17
03-01-2006 08:56 PM
Cjsls
01-17-2005 07:27 PM
