jdm b16a vs usdm b16a2
i have a b16a 1990 from japan i/h/e chipped ecu, it haules *** for what it is. but a fren in sellin a usdm b16a2 (99 si) for cheap. i read somewhere on here that the usdm dohc vtec's are the weakest dohc vtecs there are. is this true? is my 1990 jdm b16a better than a 1999 usdm b16a2?
Re: jdm b16a vs usdm b16a2 (1tyme)
Actually, the USDM B16A (B16A3 and B16A2) are better than the 1G JDM B16A. The cams are better. But it would appear that the JDM B16A (SIRI and SIRII) have more aggressive ECUs. So if anything, you would GAIN power with a USDM B16A.
Re: jdm b16a vs usdm b16a2 (b16ahybrid)
the diference between yours and his is yours is non-obd and his is obd2. compression an hp are the same...
Re: jdm b16a vs usdm b16a2 (StorminMatt)
Re: jdm b16a vs usdm b16a2 (KAMiN)
not true, the cams are milder on the first gen b16's
In general power wise they are about the same (158 hp vs 160hp), being that he was asking about the performance
Give me a break,Get the 99 are you crazy.Whatever tiny differences there are between the two would be made up in that the si motor is 8-11 years younger.Probably a lot less abuse and surely way lower miles,but anyway they were rated a the same bhp so it don't really matter anyway.Beside the obd you could use all the same I/H/E so you already got all the upgrades.
[Modified by 92b16vx, 9:26 AM 12/5/2002]
Re: jdm b16a vs usdm b16a2 (92b16vx)
He doesn't have to use the tranny, ecu, obd2 elec., ect. off the a2. Just use the longblock with your current cable tranny, distributor, injectors, header, intake, ect. and have yourself a almost new B16 with better cams. If the price is right, go for it.
Re: jdm b16a vs usdm b16a2 (nsxmatt)
heh, my turn...
All of the US B16A motors use JDM 89-91 B16A PR3 10.2cr pistons, other than that all of the US B16A motors are all the same internally, minus the usual OBD1/OBD2 components.
Like some of these guys are saying, if you get your friends motor, you'll basically have the same motor you have now, but with a hell of a lot less miles on it. I say just keep your motor as-is.
They're virtually the same motor minus the OBD complexities.
Re: jdm b16a vs usdm b16a2 (Katman)
Personally if some one offered me a motor that was ten years younger I'd take it.It's pretty much a no lose situation bro,just decide if that's what you feel like doing for a day or two.
Re: jdm b16a vs usdm b16a2 (GRCuadros)
thats not true, the compression on the JDM is a little bit higher, .2 i believe
jdm b16a sir1 has a compression ratio of 10.2:1
jdm b16a sir2 has a compression ratio of 10.4:1
and the usdm b16a2/3 has a compression ratio of 10.2:1..
so yes the usdm b16a and the jdm b16a (sir1 which he has) hav the same compression and are both rated at the same hp.....
jdm b16a sir1 has 158hp (rated) and the jdm b16a sir has 168hp and the usdm b16a2/3 has 160hp (rated)...
only the sir2 has a higher compression ratio....and your rite it's .2 higher
SuicideSlide
09-12-2006 01:16 PM
