could i run mid 13s wit this setup
A B20 with 62404s, bolt-ons and the right tranny set-up should put you in the high 13s with a good driver. Add nitrous and 12s would be possible with a good driver.
A bad driver can hit any time higher than that.
A b20 with I/H/E will put out around 140 whp and 130 ft-lbs trq @ the wheels. It will also 0WN most B16s...depending on driver..
[Modified by SuperCivic, 11:53 AM 12/2/2002]
aonick
40
May 2, 2002 11:13 AM
