very quick h22 4th gen civic ????????
ok i found loads of info and hasport has a full how to guide on the site but it says to use a lift and lower the car over the engine , now my question is as im unlikely to have access to a lift does the engine fit from the top or does it have to go in from underneath???
Re: very quick h22 4th gen civic ???????? (dazcivic)
Use a engine hoist and attatch it to your car. You should be able to lift the front end high enough with one of those
Re: very quick h22 4th gen civic ???????? (turboedsupe)
ye thought about that
i was also thinking about doing everything i can at my place and then having a word with a mate to see if i can take it to his garage just to actuall fit the engine to the mounts then back to mine for the rest of work
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dazcivic »</TD></TR><TR><TD CLASS="quote">so it does fit from the top then??</TD></TR></TABLE>
yes, w/ a lil shove and pushin', you'll need at least more person to do this while the other works the engine hoist.
gl. and keep your fingers off the back of the intake manifold while lowering it. . .
angelovargas
10-13-2003 07:01 AM
