H22 CRX VSS Not operating
Drove the car today and noticed that I was cruising at 0 mph
I checked the VSS and it's all the way in and plugged up. I used the VSS on the 91 CRX HF in the H22A motor, JDM ECU. What's a matter?
Re: H22 CRX VSS Not operating (ketchup)
Stock D series EF VSS/Speedo/Cable will work just need to make a longer clip for the smaller D series unit. Make sure the cable is cliped in and does not pull out easily lil tug, it may not be fully in?
P13 requires to be able to have the VSS working properly in order for Vtec to engage
Re: H22 CRX VSS Not operating (ESP.net)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ESP.net »</TD></TR><TR><TD CLASS="quote">Stock D series EF VSS/Speedo/Cable will work just need to make a longer clip for the smaller D series unit. Make sure the cable is cliped in and does not pull out easily lil tug, it may not be fully in?
P13 requires to be able to have the VSS working properly in order for Vtec to engage</TD></TR></TABLE>
The unit is held in by a metal bracket, it's all the way in and I took it out to re-check the connections. The cable length is realllly tight because of the rear engine mount bracket. I'll try to lightly tap it in more.
Modified by ketchup at 1:33 AM 7/11/2008
PayMecracka
04-10-2011 07:59 AM
