Map sensor and starting issues
Old Jul 19, 2008 | 04:54 PM
Rukusmasta2's Avatar
Default Car only starts with MAP unplugged?!?!??!HELP!!!!!
I try to start my swap which i just converted to obd1 from 0 and took off the fire wall mounted map and using a tb mounted one now, and my car will not start if i have it plugged in. If its not plugged in it starts fine, idles fine, throttle response is fine, and i can plug it in and still runs, but throw a code 3. So i checked my voltage and its 10.4 volts, isnt it supposed to be only 5?? someone help asap tryin to drive this thing.
Modified by Rukusmasta2 at 12:16 PM 7/20/2008
Old Jul 19, 2008 | 06:24 PM
Default Re: Map sensor and starting issues (Rukusmasta2)
bumping it, i need this answered man.
Old Jul 20, 2008 | 08:16 AM
c'mon help someone, ive searched for 4 hours on here about 1200 threads, searched on G2IC.COM and even googled this. cant find nothing.
Old Jul 20, 2008 | 04:52 PM
checked my wires over and over and over and over.................and over again. My jumper harness i bought seemed to be wired wrong, so i cut it, ran some wires direct to the ecu plugs to the MAP sensor, its good now, well i ahvent drove it, but let it sit for about 5 minutes running and no CEL. well see how it goes.
Old Jul 23, 2008 | 03:03 PM
this **** is all f*ed up cant figure it out, noe one is helping searched so much. this blows.
Old Jul 23, 2008 | 05:05 PM
bump
Old Jul 24, 2008 | 05:25 PM
some one help
Old Jul 24, 2008 | 05:34 PM
Turbogixxer's Avatar
If you are getting 10volts to the sensor two things happened. Your Map is now blown and your wiring is bad. It only should get 5v
Old Jul 25, 2008 | 02:04 AM
Default Re: (Turbogixxer)
no my bad my map 5v is now gettin 5.03 and the signal is gettin around 2
Old Jul 25, 2008 | 11:51 AM
Default Re: (Rukusmasta2)
ttt man somoene help
Old Jul 26, 2008 | 01:16 AM
mtber's Avatar
The map sensor uses 3 things. Power Supply 5 volts, Ground & Signal.
Use the wiring diagrams on http://www.phearable.net/tech to determine if everything is wired properly.
If you are still having issues, check the map sensor's output voltage at atmospheric pressure to determine if it is bad etc...
Dc_Ek
Feb 13, 2013 11:47 PM
aznfreakyguy
Jul 3, 2011 12:24 AM
slow96lude
14
Oct 10, 2009 09:56 AM
msinsky14
Nov 25, 2008 05:57 PM
JasonST
Apr 26, 2006 07:36 AM
