H22a into 92 GS-R Wiring questions
I did search but havent found what I needed. I basically swapped the h22a in with the GSR stock harness. I extended the plugs as needed and everything seems fine. I also read that I can't just put the H22a Distributor on the Harness, it has to be wired in? All the colors match up on both sides so Im not sure there. It is not sparking now and I am wondering if this is true How would I wire it in? Does what I have done sound ok so far or should I be going another way with this?
Thanks for any help,
mdj_ge
11
06-22-2004 08:47 PM
