Engine breaking up past 7K RPM please help ASAP
Hey guys i just recently did a swap to my (00'EK) i put in a (95'B18C1) Using an (00'Si Harness and ECU). At first it was NOT reving pass 4K and i fixed that problem and it started running fine but today out of the blue it started sputtering or breaking when i would hit about 7K to 8K any ideas? it didn't do that b4 it would hit 8K no problem, so im stumped what can it be any clues? One more thing sometimes the vtec won't kick in! I need help ASAP!
P.S. Could it be because im using a SI ECU instead of the GSR ECU?
Re: Engine breaking up past 7K RPM please help ASAP (2point2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TunesEK »</TD></TR><TR><TD CLASS="quote">I'm using the wrong ECU and now I have problems. What could it be?
It's probably the ECU.
No thats not my question becuase on many other fourms they say you could use an SI ECU and it should run fine, that the only problem would be that the SI ECU is a lil more sensative than the GSR ECU.
HELLO,GOOD MORNIN'
Re: Engine breaking up past 7K RPM please help ASAP (TunesEK)
the SI ecu is not going to run the car properly. it's nto much mroe to add. you cahnge the ecu and im sure your problem will dissapear
Re: Engine breaking up past 7K RPM please help ASAP (HybridcivicLS-T)
Well i fixed it after some searching and messing around the engine... i don't want put you down since y'all tried to help but like i said its not the ecu! turned out it was the dizzy it was off timing thats all! somethings are better done on your own but thanks for trying to help!
TunesEK
11
08-19-2008 06:55 PM
949
Southern California
08-18-2008 05:25 PM
