F23 SOHC Vtec into EG Questions.
So I had an H23 Vtec motor in my EG but unfortunately, it spun a rod-bearing. I managed to source an F23 SOHC Vtec engine from a 2002 Honda Accord. I was wondering, with my car being OBD 1, if all I will need to do is swap the sensors and swap the internals on the distributors.
I was also wondering if my H22 tranny will bolt straight up to the motor and if I'll be able to use the same motor mounts. Thanks.
Re: F23 SOHC Vtec into EG Questions. (StockDC2)
the tranny will bolt right up. make sure you choose h-f series swapped mounts.
and SEARCH is your best friend.
s2000june
05-13-2004 08:15 PM
