CAN I RUN A B17 CRANKSHAFT IN A B16 BLOCK????????????????
i was told the the b17/b16 blocks are the same........ so i could run a b17 crankshaft in my b16a3 block............. correct .? as long as i get the matching b17 rods/pistons.....to go with it
Re: CAN I RUN A B17 CRANKSHAFT IN A B16 BLOCK???????????????? (Shartek)
Correct, the two blocks have the same deck height so you can use the B17 crank in the B16 block, but like you said, you will also need to use the B17 rods as well for it to work.
dominicanito49
07-18-2006 06:41 PM
