Knock Sensor code after GSR swap
Old Jul 14, 2008 | 10:04 AM
b16a1eg6's Avatar
Default Knock Sensor code after GSR swap
I put a JDM B18c GSR into my 1990 STD. Runs fine if you baby it. Once you get on it the check engine light comes on. I read the code and it tells me that its the KS. When you turn the car off and back on again its gone. Could the sensor be bad or is the wiring?
I used the Boomslang OBD0 dpfi->OBD1 mpfi harness
Old Jul 14, 2008 | 02:08 PM
ekb16's Avatar
did u add a wire for the KS when u did the swap? not all cars came with a KS so when u do a swap that is one of those things u need to add
Old Jul 15, 2008 | 06:35 AM
b16a1eg6's Avatar
Default Re: (ekb16)
Yes the boomslang harness includes the KS.
Old Jul 16, 2008 | 06:58 PM
stunn'd's Avatar
Is it a shielded wire running to the ks? I know that if its just a regular wire, it will cause the cel to come on and go off exactly as you describe.
If I were you.. I would get a chipped ecu for 140bucks and disable that useless piece of ****.
Old Jul 17, 2008 | 04:26 AM
b16a1eg6's Avatar
Default Re: (stunn'd)
Ya its just a piece of reg wire. I might just have to Hondata now.
JBirch_97Prelude
May 27, 2007 01:03 PM
DRTYHARRYIII
Jun 6, 2003 09:46 AM
slo4door
10
Apr 22, 2003 08:18 AM
speshuled619
Jul 26, 2002 05:18 AM
speshuled619
Jul 25, 2002 05:12 PM
