Tranny Swap Between D Series Help
Does anyone kno how hard or if you even can and if its worth puttin a 2005 D17 civic Transmission on a 92 D16Z6 Engine i kno it sounds weird but the EX ratio in 05 are quicker, the tranny is stronger and way smoother if anyone has any info i could use all the help i can get thanks
Seagull Management
Re: Tranny Swap Between D Series Help (SleepyHatchZ6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SleepyHatchZ6 »</TD></TR><TR><TD CLASS="quote">Does anyone kno how hard or if you even can and if its worth puttin a 2005 D17 civic Transmission on a 92 D16Z6 Engine i kno it sounds weird but the EX ratio in 05 are quicker, the tranny is stronger and way smoother if anyone has any info i could use all the help i can get thanks</TD></TR></TABLE>
I don't know if it will physically bolt up. But i do know it uses a cable shifter (like a prelude) as opposed to the '92 - '00 d series trannies that use 2 metal bars for a linkage. That alone should make it not worth doing.
Mr. 1582
10-14-2003 01:37 PM
dragonhaven2001
07-09-2003 07:42 AM
