Tachometer not working?? OBDII b18c1 into an integra RS
Whats going on guys just seeing if anyone has come across this problem.
OBDII GSR swap into a 95 integra RS using an obdI P72 and an OBD II engine harness.
Evertything is woring mint except i have no tach signal at the gauge cluster... any info would be great... thanks
Re: Tachometer not working?? OBDII b18c1 into an integra RS (xtremeness101)
run a wire from your distributor(blue wire) to the distributor plug on the drivers side strut tower, its a plug that has a cap over it, should make your tach work then. I think the engine harness you are using doesnt send the signal to the cluster.
Re: Tachometer not working?? OBDII b18c1 into an integra RS (mrbob1983)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrbob1983 »</TD></TR><TR><TD CLASS="quote">run a wire from your distributor(blue wire) to the distributor plug on the drivers side strut tower, its a plug that has a cap over it, should make your tach work then. I think the engine harness you are using doesnt send the signal to the cluster. </TD></TR></TABLE>
Thanks for the response.... do ou kno the color of the wire in that harness?? RIght now the dizzy plugs blue wire is pinned to nothing on the harness that clips to it
I just dontknow what wire to jump it to?
I looked at the pinout diagram for a p72 and there is nothing that says rpm or tach signal or anything like that
either pin the car harness with a wire that mates to that blue wire or connect a wire directly to the blue wire on the dizzy and then run that wire to the one on the drivers side shock tower. Its a little plug that probably has a cap on it by itself. Hook it to that and your tach in your cluster should work.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrbob1983 »</TD></TR><TR><TD CLASS="quote">either pin the car harness with a wire that mates to that blue wire or connect a wire directly to the blue wire on the dizzy and then run that wire to the one on the drivers side shock tower. Its a little plug that probably has a cap on it by itself. Hook it to that and your tach in your cluster should work. </TD></TR></TABLE>
See i understand that i have to run a wire from the blue dizzy wire but you are refering to "the one" on the shock tower... there are no wires by themselves, there are like 4 plugs all with multiple wires in them... would you know the color of the wire on the shock tower that im looking for??
its usually a wire with a cap over it by itself. Usualy some blue electrical tape around it or something. I found this on google images, see the one with the blue tape.
ohh on the drivers side shock tower.... ive been looking on the pass side.... thanks again bro im going to check it out after work today
no problem hopefully its there it should be, i had to do this to a friends 2000 GS that we put a gsr swap in.
BukakkEK9
10-15-2006 01:01 PM
fourthgenhatchB17
12-22-2004 08:03 PM
