VSS Speed Sensor K20 swap
i have a 02-04 harness with a 06 k20z1 engine. im going to buy a speed converter box so i can get the speedometer to work but how do i hook it up if there is no 05 VSS plug on the harness? did you guys buy a cut plug and wire it directly to the ecu? the 02-04 plug on the harness doesnt fit on the 05-06 vss? what should i do.
blackoutvtec845
04-06-2014 12:48 AM
