h22 95 civic skunk2 mani
Old 08-12-2008, 03:46 PM
wfo
wfo's Avatar
Default h22 95 civic skunk2 mani
anybody running the skunk2 intake mani on there h22 swap? what all did you have to do to make it fit?
Old 08-14-2008, 12:34 PM
jdmgsr_ej1's Avatar
Default Re: h22 95 civic skunk2 mani (wfo)
I ran a Skunk2 mani on my H22 w/Hasport mounts in my 93ex and i will never do it again.
I might be able to find some pictures of it, but I basically had to beat the hell out the firewall just to get the motor to bolt up to the rear mount. Then to get the intake to fit i had to move the brake lines down for that. It was a royal pain in the ***.
Not sure if anybody else had this problem but i dont recommend it. I would just port the stock one or swap it out for the euro R mani. Im pretty sure with all the H swaps on this board somebody else has had better experiences though.
Old 08-16-2008, 01:56 PM
IMPORT JEDI's Avatar
Default Re: h22 95 civic skunk2 mani (jdmgsr_ej1)
yeah it sucks putting it on the first time.but well worth it.i have had the euro r and a hogged out stock one.and the sk2 has worked the best.this is with hcp mounts.
Modified by IMPORT JEDI at 10:38 PM 8/16/2008
Old 08-16-2008, 10:45 PM
93hatched_projekt's Avatar
Default Re: h22 95 civic skunk2 mani (IMPORT JEDI)
Just curious , did you have to pull the motor to get that skunk 2 to fit or did you disconnect a few motor mounts and push the motor forward. How did you get it on ? I know it's a crazy tight fit .
Old 08-17-2008, 03:52 PM
Default Re: h22 95 civic skunk2 mani (93hatched_projekt)
it fit right on i had already moved the brake lines and the firewall for the euro r
Old 08-19-2008, 02:32 AM
jdmgsr_ej1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93hatched_projekt &raquo;</TD></TR><TR><TD CLASS="quote">Just curious , did you have to pull the motor to get
that skunk 2 to fit or did you disconnect a few motor mounts and push the motor forward. How did you get it on ? I know it's a crazy tight fit .</TD></TR></TABLE>
While the motor was out I installed the manifold.
Old 08-21-2008, 07:55 AM
wfo
wfo's Avatar
got mine on, to get it to fit i had to knock off the studs on the fire wall, take the bracket completely off the porportional valve, and cram everything down lol, defenetly didnt like doing that to my firewall but it works, and i put mine on with the motor already in
Old 08-22-2008, 08:59 AM
91' LS-VTEC's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93hatched_projekt &raquo;</TD></TR><TR><TD CLASS="quote">Just curious , did you have to pull the motor to get that skunk 2 to fit or did you disconnect a few motor mounts and push the motor forward. How did you get it on ? I know it's a crazy tight fit .</TD></TR></TABLE>
we pulled the motor 2x. It was a b*tch. the 1st time the AICV hit the brake lines, the second time we broke the tps going backin. If I had to do it again, I would of relocated the lines lower , and use a mallet to make some more room for it. 1 bolt from the AICV is actulley touching the firewall.
I got more pics , that wheren't post on are build thread. LMK you you guys need them.
Old 08-22-2008, 09:08 AM
Default Re: h22 95 civic skunk2 mani (91' LS-VTEC)
these are pics from the 1st time the motor was in...
Old 09-14-2008, 06:32 PM
wfo
wfo's Avatar
yours fits beter than mine ^ lol, my porportional valve rattles like a ****, next step for me is brake line tuck
Old 09-18-2008, 06:27 PM
g0tuj0ckin's Avatar
Default Re: (wfo)
damn was looking forward to doing this.. but **** thats a tite fit
Old 09-18-2008, 07:01 PM
Default Re: (g0tuj0ckin)
if your motor is out. then its not a big deal. gives you a chance to clean up the firewall. If your going to try and squeeze it in. I suggest relocating as much as you can befor installing it.
Old 09-18-2008, 08:19 PM
g0tuj0ckin's Avatar
Default Re: (91' LS-VTEC)
yea my motor is already in the car...
Old 09-28-2008, 12:54 AM
omg thats a tight fit. You diffenetly gotta have the motor out first before trying to install that mani. Have you guys seen good results with this ? I just dont know if it would be worth it unless you were trying to shoot for 600whp+.
Old 10-10-2008, 09:33 PM
Default Re: (93hatched_projekt)
well since we had to replace the HG. I decided to take pics to show, how tight of a fit this IM is.
Befor this gets put back together. We are going to take a hammer to the firewall to make more room. To take the head off,we had to take the headstuds (ARP) completely out. Major PITA!
Old 10-10-2008, 09:44 PM
crx-b18c's Avatar
nice pictures
Old 10-11-2008, 02:50 AM
Default Re: (crx-b18c)
You da man ceaser , I take it the hg had nothing to do with your vtec problem. I know the IM musta been a pita...............
Old 10-12-2008, 02:15 AM
still no vtec.
I'm going to get a mallet and smack the firewall to make some room. then cleam it up and repaint it. see how much clearance I gain.
playlife
05-29-2015 04:46 PM
ranta18
08-18-2004 10:24 PM
ranta18
08-03-2004 04:12 PM
Quick Reply: h22 95 civic skunk2 mani
