LS VTEC Removing Lower Timing Gear. Searched
I got the crank pulley bolt out and the pulley off without issue. I am taking an LS crank out of a different block to put in my soon to be built LS/V
I can see in the keyway where i removed the pulley and it looks like the diameter on the lowere timing gear is smaller the the crankshaft. (Looks like a step in the Shaft) How does the lower timing gear come off
Thanks in advance
Jeremy
Thanks in advance
Jeremy
Mr. Badwrench
Re: LS VTEC Removing Lower Timing Gear. Searched (f22beast)
unless its mangled, it should slide off may take a little motivation from a flatblade, but should take little effort.
Re: LS VTEC Removing Lower Timing Gear. Searched (boostedcivicsir)
I will give it another go but i dont see how it will come off.
Ill keep you posted. I tried putting the gear puller on but cant get the jaws around it
honda_boy23
10-09-2011 08:40 AM
