Car won't rev out
Car won't rev out
I need big time help with an issue.
my car isn't revving past 6800...at first i thought it was a vtec issue, and as it turns out it isn't. It revs to 6800 even in neutral. motor is 00 euro r h2b in a 93 bubble so i did the obd2b to obd1 engine conversion. i'm still using the obd2b dizzy and i'm pretty sure its wired correctly. i have no idea what could be wrong.
i have no cel
oil is good
timing is good
ecu is good, its a p72 on s200 btw.(tested it on another car and revs out fine.)
compression is 240 across the board.
i've searched for 3 days before i posted this. all topics lead to nothing, and nothing has a resolving problem. any leads would be great, thanks.
i cut j1 to see if my map was [freak]ed, but its not. revs to 6600 or so, put in a ls computer and revs to 6000, it cuts me 1000rpms short. why?
** EDIT ** forgot to mention that it runs dumbbbbbbbbbbbbbbb rich, like i see the needle going down as i press on the gas, i don't know if its running weak cause i never had a chance to fully drive it, but it does feel very strong. i know this is a limp mode act that it put inseld into but i have no idea what set it off.
i have no cel
oil is good
timing is good
Re: (Shadowz7429)
if you are under 10mph you will not engage vtec. so if you're in nuetral or your vss isnt working you will have not vtec. And also i have a stock p13 and if i rev it up in nuetral wile im not moving it wont let me rev past 6800 rpm either. once im moving its all good tho
Re: (Shadowz7429)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Shadowz7429 »</TD></TR><TR><TD CLASS="quote">what codes do you get when you put a stock p13 in? any codes in the hondata?</TD></TR></TABLE>
i have no cel's at all
i rev it in neutral to see if it was a vtec problem. in neutral it should rev to 8200, ive tested it on another car. i'm on a p72 tuned for my regular jdm h22...
vtec hits when i drive. there is no sputter bogging-nothing its a very nice powerband and then bam a brick wall. car runs very rich, the needle actually goes down if i stomp on the gas.
the car is very well warmed up to normal operation temperature
Re: (antivic)
actually with my p72 with j1 cut i get codes 41 (o2) and knock sensor. both these codes arent a reason i'm revving so low.
on the ls computer that i have i just get a o2 code.
thats it and thats all..
i checked my timing and its on point, couldn't get any better. im so stomped on what this could be
Re: (antivic)
perhaps my car doesn't know I'm moving? my vss is working..mph go up as it should...
but if I put my p72 on an ls hatch it revs up to 8200 no problem...
I don't have a vtec pressure switch but I did the bypass by connecting a skywire from a4 to d6...but I read I should ground out the vtps straight out the ecu...but vtec hits either way...ugh...i can't figure this out haha
