obd2 to obd1 question
Old Aug 23, 2008 | 12:22 PM
dohcmotors's Avatar
Default obd2 to obd1 question
we just did a 95 gsr into a 98 civic and was wondering if there is any way i can wire in the obd1 data link connector to flash the computer to check for codes. any help would be much appreciated. im using a obd1 p72 ecu
Old Aug 23, 2008 | 05:17 PM
ekb16's Avatar
jumper the service connector and read the flashes
Old Aug 25, 2008 | 07:22 AM
dohcmotors's Avatar
Default Re: (ekb16)
that is the thing we cant jump the dlc connector no longer seeing that the swap is obd1. is there a way to wire in the jumper so that we can check any codes that we might encounter.
Old Aug 25, 2008 | 09:38 AM
LA_HONDAS's Avatar
Default Re: (dohcmotors)
on a obd1 ecu you can take the wire on plug D pin 4 and hold it on a ground
to read the codes
ericrcan
Dec 8, 2023 05:05 PM
Hockey27925
Aug 22, 2005 08:17 PM
anduknodis
Sep 18, 2004 11:54 AM
quikB18B
Apr 14, 2002 08:48 AM
